TwinTurbo.NET: Nissan 300ZX forum - rich fuel smell, not propane (n/m)
Jonezy
on October 26, 2004 at 1:03 PM
Does it smell more like gasoline or propane?
posted by just4kinks
on October 26, 2004 at 12:37 PM
Post ONE annoying thing your Z does and you can't figure out
SeedyROM
12:18:25 10/26/04
Both driver and passenger seats have play/wiggle in them
SeedyROM
12:22:12 10/26/04
Yes! I hate that! (n/m)
Rodger
12:51:16 10/26/04
My driver's side seat does something similar.
Dustin
12:55:21 10/26/04
There is a hook and a rod that hold the seat in the "upright
Barry'Z(NJ)
13:03:04 10/26/04
Very interesting! Bet Bernie doesn't have that pic ;)
SeedyROM
13:14:48 10/26/04
Shouldn't need to remove the seat,
Barry'Z(NJ)
13:38:43 10/26/04
Re: Both driver and passenger seats have play/wiggle in them
gavorney
13:56:22 10/26/04
I made a post about my seat wiggle fix a few months ago
Zenn
15:08:36 10/26/04
But mine are manual seats
SeedyROM
15:19:39 10/26/04
Hey Ryan, the issue Iwas addressing was only
Barry'Z(NJ)
15:39:27 10/26/04
Hey Ryan, here's a pic of what I was talking about
Barry'Z(NJ)
17:30:20 10/26/04
Perfect! Thanks!!!
SeedyROM
19:30:30 10/26/04
nissan sell those parts for replacement? my pass side
takirb
20:06:15 10/26/04
www.24hourfitness.com (n/m)
PLEAZURE in CA (SD)
18:27:36 10/26/04
I have 2 annoyances right now
ImTheDevil
12:25:08 10/26/04
Does it follow a pattern? Is it the idle you notice
SeedyROM
12:34:31 10/26/04
it was the idle
ImTheDevil
12:41:34 10/26/04
When cold or even when warm?
SeedyROM
12:47:12 10/26/04
The noise my credit card company makes
twinzak
12:28:36 10/26/04
The hood is tweeked after I open and close it
UnrulyZ
12:29:14 10/26/04
maybe tweak the hood adjustment grommets? (n/m)
dragknt
00:30:42 10/27/04
HICAS light kicks on every once in a while, usually
YugoBernie (NoVA)
12:29:17 10/26/04
I can't get rid of my gas smell.
Jonezy
12:34:23 10/26/04
Have you replaced your gas cap?
SeedyROM
12:36:02 10/26/04
interesting, seems like it is coming from under the hood
Jonezy
12:57:49 10/26/04
maybe its inside the car?
UnrulyZ
12:36:17 10/26/04
okay, haven't done that either, thanks (n/m)
Jonezy
12:58:39 10/26/04
Replaced the gas cap? Check the Carbon Canister connections
YugoBernie (NoVA)
12:37:03 10/26/04
carbon canister connections are new
Jonezy
13:02:45 10/26/04
there is a set of rubber lines that connect the 2. (n/m)
YugoBernie (NoVA)
13:15:37 10/26/04
I am pretty sure i changed them when the engine was out.
Jonezy
13:18:12 10/26/04
just4kinks
12:37:55 10/26/04
rich fuel smell, not propane (n/m) -
Jonezy
13:03:29 10/26/04
Re: I can't get rid of my gas smell. - fuel prsr regulator
ironhawk_ca
18:57:00 10/26/04
Glove compartment won't close/line up properly (n/m)
Z-Tarded(Corpus)
12:36:00 10/26/04
Breaks down every 4-5 months... (n/m)
boileralum
12:37:01 10/26/04
hehe yeah that's pretty annoying (n/m)
tommunist
19:32:50 10/26/04
I have to open my hood like "the Fonz"
fantomZ(OH)
12:39:59 10/26/04
high idle after running at Hallett...
Tu
12:41:28 10/26/04
o2 sensors may also be fouled from what ever that middle
YugoBernie (NoVA)
12:44:17 10/26/04
Ah, that's very possible
SeedyROM
12:49:06 10/26/04
that stuff was 91 crap ... lotta cars were pinging (n/m)
Guapo
12:54:15 10/26/04
A longshot since you have an NA but...
SeedyROM
12:46:32 10/26/04
The dreaded 2nd windshiled wiper swipe when you turn it off
College Boy
12:42:31 10/26/04
Maybe I'm weird but this really has never bothered me. (n/m)
YugoBernie (NoVA)
12:45:04 10/26/04
just bothers me when i flip it once to swipe once, and it do
College Boy
12:47:16 10/26/04
2nd (n/m)
dragknt
00:33:06 10/27/04
I hate how the "Rec" switch resests itself every 10-15 min
PLEAZURE in CA (SD)
17:19:30 10/27/04
2nd. That's more a design issue than a problem really
SeedyROM
12:48:12 10/26/04
your weird (n/m)
JDMz32smity
12:48:31 10/26/04
i can live with it (n/m)
90BlkZ18
12:49:47 10/26/04
power steering goes out for a day when I do a hard run
komplexZ(Orlando)
12:47:28 10/26/04
Could it be your "smoking" your PS belt and then it slips
Unluky (MO)
13:44:02 10/26/04
good idea, I'll have to try, thnx :) (n/m)
komplexZ(Orlando)
16:21:26 10/26/04
There is a LED on the right hand side of my clock,
Barry'Z(NJ)
12:48:34 10/26/04
Did you grease the latch itself?
SeedyROM
12:50:09 10/26/04
Not yet but, I will soon. Thanks (n/m)
Barry'Z(NJ)
12:52:19 10/26/04
AM/PM? Random LEDs are not part of the stock clock. (n/m)
YugoBernie (NoVA)
12:52:27 10/26/04
I think you are seeing red light reflected back from inside
zxjpmzx
12:54:44 10/26/04
Cool, Thanks (n/m)
Barry'Z(NJ)
12:56:18 10/26/04
That' a UFO detector - be careful when it lites up... :) (n/m)
jzack
21:29:28 10/26/04
Some kind of power drain kills battery in 2 weeks of sitting
Technomancer
12:55:13 10/26/04
Re: Post ONE annoying thing your Z does and you can't figure out
Touchless
12:56:17 10/26/04
You should let your car get to operating temp
Dustin
13:11:03 10/26/04
Cold hesitation is mostly corroded connectors or bad injecto
PLEAZURE in CA (SD)
18:05:11 10/26/04
brake creak could be worn out/old shims, or ungreased shims. (n/m)
dragknt
00:34:53 10/27/04
Busted clutch booster that causes a nasty vacuum leak (n/m)
U ZCREAM
12:56:37 10/26/04
I thought & thought & thought..can't think of anything wrong
zxjpmzx
12:58:29 10/26/04
it doesn't run. i think the engine blew. (n/m)
jpark74
13:01:42 10/26/04
Intermittent Lifter tick and AIV gurgling
sfpearl300z (South Florida)
13:02:11 10/26/04
I have a ticking lifter sometimes
Jonezy
13:07:53 10/26/04
Passenger side turn signals blink at super fast pace
zxerox
13:03:27 10/26/04
inspect bubls.. clean corrosion
90BlkZ18
13:11:25 10/26/04
I've noticed this twice on my 94TT...once about 4 years
zxjpmzx
13:11:34 10/26/04
Yup. (n/m)
YugoBernie (NoVA)
13:16:37 10/26/04
clutch chatter (n/m)
takirb
13:04:18 10/26/04
big 2nd. it gets so annoying when clutch heats up (n/m)
stockplayerz (NYC)
13:06:54 10/26/04
Then you need to bleed your system and adjust the pedal. (n/m)
YugoBernie (NoVA)
13:17:11 10/26/04
i've done both, and it cures it for only a day or so..
takirb
13:31:00 10/26/04
will pedal adjustment cure chatter? hmm >>
stockplayerz (NYC)
14:51:16 10/26/04
To me it sounds like you have air in the lines and it change
YugoBernie (NoVA)
14:56:27 10/26/04
what clutch? update profile (n/m)
Scotts94z32
13:13:39 10/26/04
not a performance clutch, something called a Zoom clutch
takirb
13:30:00 10/26/04
A moving eng. point means air in the system. (n/m)
YugoBernie (NoVA)
16:12:08 10/26/04
also, i get the "chatter" anytime i slowly engage reverse.
takirb
16:55:34 10/26/04
Brake warning light.
Kenny
13:09:38 10/26/04
Non-Nissan bulbs in high mount 3rd light. (n/m)
YugoBernie (NoVA)
13:18:01 10/26/04
This is a new one. I will try it, thanks Bern =). (n/m)
Kenny
13:40:22 10/26/04
Re: Brake warning light.
outkaZTT
13:20:15 10/26/04
Connector is clean =). (n/m)
Kenny
13:39:47 10/26/04
i used to have same thing
JDMz32smity
13:21:24 10/26/04
Refill your brake master cylinder. (n/m)
MOTRSPRT--ID
13:35:01 10/26/04
It's full. Warning light only comes on when I tap brakes. (n/m)
Kenny
13:39:12 10/26/04
Bad or wrong bulbs. (n/m)
boileralum
13:43:43 10/26/04
All bulbs light up... methinks they are "wrong" (n/m)
Kenny
14:22:26 10/26/04
/me concurs (n/m)
boileralum
15:17:02 10/26/04
had that light coming on while driving a great winding road
Technomancer
13:43:27 10/26/04
lol. Fluid level was probably sloshing around, and read...
Kenny
23:26:58 10/26/04
But that turns on the HICAS lite, not the brake warning lite
Technomancer
14:17:10 10/27/04
she's been running rich since i replaced my engine
jay2dav
13:11:51 10/26/04
My seat tilts back and the seat belt locks in place
twinzak
13:13:02 10/26/04
takes all my money (n/m)
joel(PA)
13:14:59 10/26/04
2nd (n/m)
NATHAN91'TT
13:19:35 10/26/04
Hmm... that problem's not easily fixed. (n/m)
Z-Jay (Edmonton, AB)
15:34:11 10/26/04
Intermittent HIGH idle, and small PS fluid leak (keep having
13:16:38 10/26/04
Thread hijack: Were you successful with removing your lower
Dave N
13:22:28 10/26/04
Haven't had time yet. Had to work late yesterday. Maybe
15:33:20 10/26/04
You've got mail. Using the pickle fork makes the job a lot
Dave N
12:35:16 10/27/04
Rear view mirror.
ZHOUND
13:19:17 10/26/04
Silicone it ;)
SeedyROM
13:23:00 10/26/04
Flip switch is broken - easiest thing to do is just buy a
YugoBernie (NoVA)
13:28:38 10/26/04
Wanna trade motors instead of mirrors? (n/m)
kryptonite729
16:28:25 10/26/04
:-) (n/m)
ZHOUND
14:08:19 10/27/04
The "click" noise from the rear end
The-FActor
13:21:28 10/26/04
Can you also feel the click or is it audible only?
SeedyROM
13:26:11 10/26/04
2nd, same here (n/m)
dragknt
00:38:00 10/27/04
HMMMMM where to start
dvlhntr
13:27:29 10/26/04
Driver side window rattles when open...
Slobo7x
13:36:31 10/26/04
search this site and possibly find it in yahoo, but theres
takirb
13:40:52 10/26/04
Got that as well
dvlhntr
13:52:22 10/26/04
creaking noise on my front end, NO small storage
BoostLesZ
13:47:50 10/26/04
2nd and 4th gear make odd noise, and AC/heater relays
jkeyser14
13:50:50 10/26/04
Re: 2nd and 4th gear make odd noise, and AC/heater relays
zed4life
18:43:44 10/26/04
Engine knocks....
Zluster
13:51:45 10/26/04
Steering wheel moves from side to side horizontally about a
longhornz32(Dallas)
13:54:16 10/26/04
Check mounting bolts to the under dash cross-member. (n/m)
YugoBernie (NoVA)
14:57:51 10/26/04
Thanks, could this be related to my power steering going in
longhornz32(Dallas)
15:09:46 10/26/04
Mmm... doubt it, that's prob. belt tension, air in the lines
YugoBernie (NoVA)
15:32:50 10/26/04
Squeeks around passenger A pillar area and dash>>
Spectrum (WI)
14:04:48 10/26/04
You're missing the screws that holds the pods to the top
PLEAZURE in CA (SD)
18:10:03 10/26/04
Wipers! I turnoff the intermittant & it does 1 more swipe (n/m)
NAZTTy
14:10:15 10/26/04
Where to start...
ZXRider
14:15:48 10/26/04
Oh ya
ZXRider
14:19:24 10/26/04
LOL
14:53:45 10/26/04
aw i hope your not laughing at me =(
ZXRider
15:18:42 10/26/04
Not laughing AT you, laughin WITH you
15:37:31 10/26/04
Well it is funny
ZXRider
15:46:13 10/26/04
haha .. easy fix, switch the hoses under the water bottle in
PLEAZURE in CA (SD)
18:11:39 10/26/04
Take a look
ZXRider
19:32:25 10/26/04
Thanks for trying tho. (n/m)
ZXRider
19:33:16 10/26/04
diff rattles... or is it the tranny... or is it both... damn
Scotts94z32
14:42:13 10/26/04
why they didnt put cupholders (n/m)
Malukalu99
15:34:04 10/26/04
my girlfriend complaining about all the Z's annoyances...
BradZ (FL)
15:48:05 10/26/04
ash tray/coin collecter rattles (n/m)
Z32Nizzan
16:06:27 10/26/04
The whole thing or just the change in it?
ImTheDevil
16:18:23 10/26/04
2nd, i have a paper towel under mine to catch condensation
takirb
20:04:12 10/26/04
under full boost I hear a scary noise coming from the...
PunkZTT(Phoenix)
16:11:44 10/26/04
I think that's your fuel pump stepping up the pressure. (n/m)
YugoBernie (NoVA)
16:12:48 10/26/04
Ill go back there and investigate more tonight....
PunkZTT(Phoenix)
16:16:39 10/26/04
It's under the "amp rack" as you put it.
spicyZ
19:38:44 10/26/04
Only when below 50 degrees I get a wannabe knock.
Kez43
16:42:28 10/26/04
I replaced the window slider, but the window still rattles
PLEAZURE in CA (SD)
17:59:46 10/26/04
Check all the mounting bolts and nuts on the tracks..
Spddracer
20:13:12 10/26/04
nope, I said the wheel is loose on the track itself
PLEAZURE in CA (SD)
12:28:24 10/27/04
Check your lock bolts...mine came loose again.
SuparexTT
23:06:51 10/26/04
My window is rattling, not the door. (n/m)
PLEAZURE in CA (SD)
12:30:01 10/27/04
occassionally my greddy electronic boost and fuel
Slowninja(Sport600 Inconel Z)
19:33:06 10/26/04
no tilt steering wheel ! (n/m)
19:37:01 10/26/04
no more titanium key blanks ! (n/m)
19:44:38 10/26/04
no switch to automatically lower passenger window
19:51:15 10/26/04
You got a lazy g/f or wife? I know wining could be vexing
PLEAZURE in CA (SD)
12:32:59 10/27/04
Hard to work on compared to L6 Z's. (n/m)
Got Z?
22:34:32 10/26/04
illuminated key light on door doesnt light up with handle
23:01:22 10/26/04
My lovely T-top leak taunts me.
SuparexTT
23:14:20 10/26/04
interior fills with exhaust fumes and makes me sleepy tired (n/m)
2eZee
23:29:12 10/26/04
LOL I hope you're joking
SeedyROM
09:41:46 10/27/04
I thought exhaust fumes should only come out from the back
PLEAZURE in CA (SD)
12:36:44 10/27/04
Exactly
SeedyROM
14:24:43 10/27/04
